It is currently Mon Aug 11, 2025 6:52 pm
 Post subject: Drying in the oven
PostPosted: Sat Oct 01, 2016 10:32 am
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
In the spring I was given a piece of an Ash tree that was taken down off a friend’s West Virginia farm because of the Emerald Ash Borer. The piece had been felled for almost a year at that time, and we split 1/4 out of 28” diameter section and I brought it home. A couple of months ago I cut it up into guitar wood - the reference face was a really nice split surface - straight and straight grained. The pieces for the body are shy of 3/16” thick, so they are close to dry enough for guitar use, but I have a 3” X 4” piece for a neck. It is almost perfectly quartered on the 3” side. I would like to build a Resonator guitar this winter and need the neck to be dry (actually I have all the parts and am itching to start).
Last weekend I drew the outline of the neck on the block, then added about 1/2” in all directions. My intention is to cut out this oversized piece, and then even if it dries with a little movement there will be enough to get my neck out of, but at least it will dry more quickly than the full size block. I have not made the cut, because every time I do, I always say to myself “that would have looked better if I moved it over and inch on the block”. I am giving myself some time to look at it more before I cut.
So a question - what would happen if I turned the oven on and put the oversized-cut neck piece in there to dry it? What temperature - 120°? 140? How much time - a week? a month? Better to put it in the oven for some time, then take it out for some time, then back in? How about a pan of water in the oven for a while to temper the drying? I can build a box with a lightbulb to get similar temps - how much time?
Any thoughts will be appreciated.
Just read a scientific paper on drying, and a 10" thick piece of oak will take about 30 years to air dry!!!
Ed
 Post subject: Re: Drying in the oven
PostPosted: Sat Oct 01, 2016 11:00 am
Last Name: McDonald
City: Okanagan Centre
State: British Columbia
Zip/Postal Code: V4V2H6
See if there is a local mill with a kiln. We have many around here and some are open to accepting odd pieces.
B
These users thanked the author Bri for the post: simple (Sun Oct 09, 2016 11:45 am)
PostPosted: Sat Oct 01, 2016 5:17 pm
Drying wood won't happen in a kitchen oven. To dry wood properly it can take about 1 year per inch under good conditions . To kiln dry it this takes a special piece of equipment. We had a Kiln at the sawmill that operated first on air circulation and dehumidifcation to get the wood to about 20% then heat was added , this process from the day the kiln was sealed till the wood was down to 6-8% would take about 30 days. Again that depends on the kiln and the type of kiln.
Now high tech kilns that use RF waves and vacuum can do the process in about 5 days but is often used in specialty woods and Pattern making.
PostPosted: Sat Oct 01, 2016 8:29 pm
First name: Fred
City: Winnipeg
There is no real shortcut if you want to use it as guitar wood. A kiln is about the fastest method where you would get reasonably stable wood. I want to build a little temperature and humidity controlled kiln, you need to control both if you want to do a good job and as John said, it will take a while.
PostPosted: Sat Oct 01, 2016 9:38 pm
First name: D
Last Name: S
Ed,
I dried some home-harvested Ash in my garage.
I cut 1/2" planks while the wood was still green, stickered them, and left them in the garage for about 6 months.
The garage temp varied from about 70F to 100F.
Some of the pieces had a tendency to warp while drying.
Worked Ok for a solid top glued to a hunk of Mahogany.
Somehow this tree was in full leaf this year, despite the big missing chunk.
Dan
wah
Wah-wah-wah-wah
Wah
PostPosted: Sun Oct 02, 2016 5:52 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
You look so differen't clean shaven whith short hair!
Bryan Bear PMoMC
These users thanked the author Bryan Bear for the post (total 2): charlton (Wed Oct 05, 2016 9:12 pm) • jack (Mon Oct 03, 2016 7:12 pm)
PostPosted: Sun Oct 02, 2016 6:34 pm
First name: D
Last Name: S
Ha ha, my kung-fu days are over.
Now I'm just one of those old hippie guys.
Thanks Bryan!
wah
Wah-wah-wah-wah
Wah
These users thanked the author dzsmith for the post: Bryan Bear (Sun Oct 02, 2016 7:29 pm)
PostPosted: Sun Oct 02, 2016 7:23 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Love that guitar, Dan! [:Y:] ....and you look quite distinguished! :D
Alex
These users thanked the author Alex Kleon for the post: dzsmith (Sun Oct 02, 2016 7:42 pm)
PostPosted: Sun Oct 02, 2016 7:44 pm
First name: D
Last Name: S
Alex
Thanks Alex!
A storm broke a main trunk of this Ash tree.
Same storm broke of chunk of Mesquite at my neighbor's house.
Used both for this guitar.
Dan
wah
Wah-wah-wah-wah
Wah
These users thanked the author dzsmith for the post: jack (Mon Oct 03, 2016 7:13 pm)
PostPosted: Mon Oct 03, 2016 10:33 am
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
Looks like you'll have the rest of that tree to dry pretty soon.
These users thanked the author Quine for the post: dzsmith (Mon Oct 03, 2016 12:31 pm)
PostPosted: Mon Oct 03, 2016 6:43 pm
Last Name: Spector
City: ORANGE
Zip/Postal Code: 77632
I use my BBQ pit (no fire) to dry sides and backs this last summer. In (A.M.) out(P.M.) Did that every day for about 2-wks and the moisture meter read 8%
PostPosted: Wed Oct 05, 2016 8:54 am
First name: Leonard
Last Name: Duke
City: Kalamazoo
Zip/Postal Code: 49001
A book called Understanding Wood, by Hoadley, gives the theory and practice of wood drying. Amazon has used copies. As I remember, you can harm the wood by drying it too fast. The outside wood shrinks and hurts the inside wood. then, one kind of drying damage can be fixed but another can't. Before I tried home drying experiments I would read Hoadley's book again.
PostPosted: Wed Oct 05, 2016 4:39 pm
I have never tried this for guitar wood but I use a microwave to dry wood after I have carved it wet. I keep it wet and at the end of the time I am working it will often spray it with water. I then put it back in the freezer. Next time I want to carve I take it out and carve it and do the same. After a few times I now lower freeze it but just carve it and spritz it then put it back in the plastic bag. Finally when I have it carved but not completely sanded or finished I put it in a microwave for about 1 minute. I then take it out and set it in a cardboard box making kind of a tent over it with the plastic bag. When it has cooled I weigh it on a scale and record the weight. I then put it back in the microwave and continue the process until I have put it in two or three times and there is no change in the weight.
From there I let it set in the air for a couple days and then start sanding and finishing the piece.
I found one of those old large microwaves to do this so I could put in a pretty nice size piece.
I dn't have any idea of this would help with drying guitar wood like for the tops or the backs but I may just see the next time I get some free wet wood big enough to work for tops or backs or braces.
Understand I a m a beginner at this and have no knowledge about guitar building but I have done considerable carvings of busts and North West masks.
Chuck
PostPosted: Wed Oct 05, 2016 9:12 pm
First name: Charlton
Last Name: Wang
That was going to be my comment. :) [:Y:]
PostPosted: Thu Oct 06, 2016 6:11 pm
First name: D
Last Name: S
Ha ha.
Well, Thursday night is still kung-fu movie night at the old Smith place, so I'd better claim my seat.
Hi-yah!
wah
Wah-wah-wah-wah
Wah
PostPosted: Thu Oct 06, 2016 6:38 pm
First name: Alex
Last Name: Kleon
City: Whitby
I baked some maple and cherry boards in the oven, once. Wife didn't much care for the week of burnt maple syrup smell in the house. The cherry was dark about 3/16" deep, the maple lightly toasted.
It was suggested that I experiment in someone else's kitchen.
Alex
These users thanked the author Alex Kleon for the post: dzsmith (Fri Oct 07, 2016 8:35 am)
PostPosted: Thu Oct 06, 2016 8:05 pm
City: Escondido
Zip/Postal Code: 92029
I do most of my wood drying in this mobile kiln (often unintentionally):
These users thanked the author rlrhett for the post: dzsmith (Fri Oct 07, 2016 8:35 am)
PostPosted: Thu Oct 06, 2016 9:39 pm
Last Name: Farmer
City: Durango
State: CO
I get a lot of business from those "mobile kilns." Customers seem to find wood drys much faster in them when the pieces are under .120" thick.
Users browsing this forum: Michaeldc and 27 guests
